Problems reading from Hameg 4040 via VISA RS232
Hello Guys!
I'm trying to control my Hameg 4040 Power Supply via SCPI over VISA (RS232).
Writing works fine, but Reading back values won't work.
Tried to do a simple Test.vi which should just set voltage and current.
after this i want to read back my actual voltage.
I took the example SCPI codes from the manual, so should work (i think...)
Here is my VI and FGV
FGV
Maybe someone could figure out my problem?!
br
Sagi
Message 1 of 15
(6,335 Views)
Found the Problem, but cant really understand why it behaves like that...
The while loop runs always three times... with two iterations no value have been read by then...
Message 2 of 15
(6,325 Views)
Next "funny" thing is that if I use the provided Express VIs reading is quiet fast, but for now i can't see dthe difference to my code...
Message 3 of 15
(6,316 Views)
Hello Sagme_Mi,
I assume you are reading too fast, after sending the command. I attached a VI, which shows how I approach an Write-Read Operation. I also attached a snapshot of the block diagram for the case you're using an older version of LabVIEW.
If the builder of the express VI hasn't this option, here is how you can see the code inside an express VI.
Right click on the express VI>>open front panel>>click "Yes" on the dialog
kind regards
Message 4 of 15
(6,285 Views)
sorry,
If the builder of the express VI hasn't blocked this option...
Message 5 of 15
(6,269 Views)
@HeinzGebel wrote:
Hello Sagme_Mi,
I assume you are reading too fast, after sending the command. with this encluded1!.PNG
Heinz, You can safely execute the loop 0 times if you put the VISA Resource on a shift register
"Should be" isn't "Is" -Jay
Message 6 of 15
(6,261 Views)
Hi Jeff,
I tried and it works. Thanks a lot for your advice.
Kind regards
Heinz
Message 7 of 15
(6,243 Views)
Hi!
I tried to open the Front Panel of the Express VIs, it's blocked 😕
So it is not possible to have a look behind the scenes...
I also tried your solution(s) I have the same problems as before.
Do I miss an important VISA setting, which the express VIs might set?
For now I use only:
-BaudRate(9600), I also tried faster rates but everything above 19200 doesnt work for writing either
-Timeout (2000)
-Parity None (as selected on the PS)
-Stop Bits 1 (also, as selected on the PS)
I also have found a problem in writing mode...
I cant set all four channels to a specified value:
What i dont understand is, after running trough this section, the PS have selected OUT1 with the right value but not one of the other channels.
!!!Also if i change the order of my string array...!!!
br
Sagme_Mi
Message 8 of 15
(6,238 Views)
Accepted by Sagme_Mi
Hi Sagme_Mi,
I have some more questions for you:
1. What "timeout in ms" did you set in my vi?
2. How many bytes are you expecting and how many do you get? Do you get any at all?
3. Maybe the hameg is waiting fo an termination character like 0x0A. Do you send one?
First of all I would try to establish the communication with an Hyperterminal like HTerm.
There are also several free tools to monitor the communication over your COM-Port. With such a tool you could observe what the expressVI is doing differently than your VI.
Kind regards
heinz
Message 9 of 15
(6,228 Views)
If you want to see what the Express vi's are doing Hyperterminal won't help.  Unless you have two spare com ports and a "Sniffer" program VISA should lock access to the port and prevent hyperterminal from accessing the stream.  NI SPY will help here  (Heinz, are you  NI employee or are you just "accidentally blue"?)
Sagme, Can you link to the users manual for the device?  It is likely that the express vi drivers did not account for some features of the device.
Message 10 of 15
(6,221 Views)
