05-13-2009 09:45 AM
Hi Dennis,
Thanks a lot for your atention!
The both PCs have Labview.
I could not find "categories" and NI-VISA in the project. I downloaded the NI-VISA runtime engine and I will instal in the pc, maybe appears this option. Do you have some idea if it is possible do upgrade of path or set of gpib tools, like write, read, etc?
Milton
05-13-2009 10:08 AM - edited 05-13-2009 10:09 AM
Below is the installer properties. Categories is the box on the left side. On the additional installers page, NI-VISA is listed towards the bottom.
I don't understand your other question.
Did you ever confirm whether your application does or does not use VISA? If it does not, then this is all a waste of time.
05-13-2009 10:28 AM - edited 05-13-2009 10:31 AM
Hi Dennis,
I mean with my question: maybe the vi was wrote with typical drivers path or something like that, as a root. If it is happen, perhaps I could do a upgrade at the new PC. And the PC could identify such path. But okey, let me know if there is sense in my question.
I have already checked the visa. They answered if I wrote, set values and I could read answers from the instruments. I will try your solution.
Thanks a lot!
Milton
05-13-2009 10:43 AM
If installing NI-VISA does not solve your problem, why don't you attach the VI?
If your VI is using paths, that is something that you can verify by actually looking at the code. There is nothing that you need to be concerned about with paths to the actual hardware driver.
05-13-2009 11:01 AM
Hi Dennis,
I pasted all of objetcs (SubVI's) and so on. Also with the project. I will read something related to projects. At least I learn something new. I do not understand why I could not copy simple a code (VI) and it doesn't work in an other machine. But okey, you help me a lot.
