Problem to run a Labview program in other pc
Hi Dennis,
Thanks a lot for your atention!
The both PCs have Labview.
I could not find "categories" and NI-VISA in the project. I downloaded the NI-VISA runtime engine and I will instal in the pc, maybe appears this option. Do you have some idea if it is possible do upgrade of path or set of gpib tools, like write, read, etc?
Milton
Message 11 of 15
(1,506 Views)
Below is the installer properties. Categories is the box on the left side. On the additional installers page, NI-VISA is listed towards the bottom.
I don't understand your other question.
Did you ever confirm whether your application does or does not use VISA? If it does not, then this is all a waste of time.
Message Edited by Dennis Knutson on 05-13-2009 09:09 AM
Message 12 of 15
(1,505 Views)
Hi Dennis,
I mean with my question: maybe the vi was wrote with typical drivers path or something like that, as a root. If it is happen, perhaps I could do a upgrade at the new PC. And the PC could identify such path. But okey, let me know if there is sense in my question.
I have already checked the visa. They answered if I wrote, set values and I could read answers from the instruments. I will try your solution.
Thanks a lot!
Milton
Message Edited by Milton Baptista on 05-13-2009 10:31 AM
Message 13 of 15
(1,500 Views)
Accepted by topic author Milton Baptista
If installing NI-VISA does not solve your problem, why don't you attach the VI?
If your VI is using paths, that is something that you can verify by actually looking at the code. There is nothing that you need to be concerned about with paths to the actual hardware driver.
Message 14 of 15
(1,494 Views)
Hi Dennis,
I pasted all of objetcs (SubVI's) and so on. Also with the project. I will read something related to projects. At least I learn something new. I do not understand why I could not copy simple a code (VI) and it doesn't work in an other  machine. But okey, you help me a lot.
Message 15 of 15
(1,490 Views)
