08-17-2017 08:53 AM
Hi ,
I am trying to access the parallel port and use it as a general purpose I/O , i used VISA , but it only access 8 bits (pin 2->9) and pins 11 , 12 must be grounded.
I want to use the pins from (1 to 17) as Inputs and outputs.
I am using labview 16.
Thank you.
08-18-2017 04:55 PM
Hi hosa200
here is a link that might help
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
have a great day
08-18-2017 05:02 PM
Hi andr3s ,
Thank you for your effort.
I already checked this link and tried the first method which is great but it only output signal from 2 to 9, so I can't get input to the system.
The second and third methods use an old VIs which not supported by my LabVIEW 16.
and thank you again for your effort
08-21-2017 12:45 PM
You should be able to change the property node from write to read in order to read the data bits from the printer port.
