NI-VISA in Open Suse 12.1 and USB
Hi marjekbir1,
Do you have more than 4 gb of ram on your computer?
Also here is similar discussion.
Paolo F.
Message 11 of 15
(2,056 Views)
Hi Paolo,
Yes, this is a good discussion that you sent me.
I will try those recommandations next week. and i will advise you if i get some thing.
Thank you a lot for your help.
a.s
T&B
Message 12 of 15
(2,049 Views)
Hi Paolo,
I read the full discusion about this error, and i did all step recommanded,
I added the memory of kernet parameter in /boot/grub/menu.lst: "memmap=60G$0x100000000" .
But i can't get a good result, every time a  i execute lsdaq for nidaq or Nivisaic for NIvisa i have the same error, so this error not related to the memory of kernel.
let me know if you have any addition.
Thank you a lot for your time.
Message 13 of 15
(2,033 Views)
Hi Paolo,
Good morning, The NI-VISA can't works with USB on opensuse 12.1 to control the intrument N9000A or N1996A . Now , i ask you if this lib NI-visa can works with Ethernet Cable(RG45) to control the instrument N9000A(Agilent)?
if yes could you refere to me the steps that can help me to configure everything ?
Thank you.
a.s
T&B
Message 14 of 15
(2,017 Views)
Hi marjekbir1,
Yes you should be able to communicate to a device with Ethernet using NI-VISA. Here is the resource that states this.
Here is a resource that gives you steps to set it up.
We also have a driver for that device for LabVIEW and Labwindows/CVI.
Paolo F.
Message 15 of 15
(2,000 Views)
