Create oscilloscope driver
II have an osilloscope agilent that i should create his driver  with visa instrument controle ,have you any document that can help me,
should i based  on c/c++ driver  ???
thanks
Message 1 of 21
(6,448 Views)
You've checked with agilent and they don't have a driver? For c, IVI-C drivers are common. There are also IVI-COM and IVI-.NET. Specs are at ivifoundation.org.
Message 2 of 21
(6,437 Views)
This one is probably found on instrument driver net
goto hel find instrument driver in LabVIEW and see what happens
greetings from the Netherlands
Message 3 of 21
(6,432 Views)
 have the driver but i have a problem so i decided to developping my own driver to ovoid this probleme and to much learn
LabVIEW Instrument Driver Development
thanks 🙂
Message 4 of 21
(6,431 Views)
If you are using LabVIEW, why ask about c/c++?
If you have a problem with a driver, you need to provide details on what the problem is. And in any case, it is far simpler to modify an existing driver than to create one from scratch.
Message 5 of 21
(6,424 Views)
you are right ,but to correct this problem i have to understand the driver ,
I'am sorry i thinked that write buffer is a command to  call function (in .DLL files)  🙂
Message 6 of 21
(6,409 Views)
You probably need to take the LabVIEW fundamentals classes or at the very least, some of the free tutorials. You should also have context help open. Format Into String and Scan from String are pretty fundamental.
While it's nice for you to look at the block diagram, is there an actual problem where you are getting an error?
Message 7 of 21
(6,383 Views)
The commands you do not understand are instrument commands, not LabVIEW. They parts of a string being sent to the oscilloscope. Consult the manual for the instrument to understand what they do.
Lynn
Message 8 of 21
(6,375 Views)
What does the driver not do that you need it to?  Or do you just not understand what you need to call?
Message 9 of 21
(6,353 Views)
yes,just i need to understand to call functions 🙂
Message 10 of 21
(6,322 Views)
