NI VISA USB RAW Communication in C#
Hello
        I am Nectar,
        I am using NI Visa to communicate with my Evaluation Board.
        The sequence that I follow to communicate is given below:
        1. Create a Usb raw session
            mySession = (UsbRaw)ResourceManager.GetLocalManager().Open(resources[1]);
        2. I set the ControlOut method with the below parameters:
            mySession.ControlOut(
                    Convert.ToInt16(0x80),
                    Convert.ToInt16(0x00),
                    buffer);
            When I use this I get the exception with the message below:
            "The value of some parameter (which parameter is not known) is invalid. VISA error  code -1073807240 (0xBFFF0078), ErrorInvalidParameter"
Is there any other settings or attributes has to be done?
Is there any documentation for the C# UsbRaw class?
I searched many NI forums but not able to sort out the issue.
Please help me in this issue.
Regards
Nectar Jinil
(6,140 Views)
Hi Nectar
Yes, there is some available documentation on C# USB RAW. I am sharing the same.
USB Instrument Control Tutorial
Feel free to revert if you have any further queries.
Regards
Krishna Prasad
(6,130 Views)
