NI 9207 does not show up in MAX
I am using an NI 9207 device. This device does not show up in the Measurement and Automation Explorer. It is connected via a NI USB 9162 carrier. I have used numerous other  cartridges which all worked in this combination. I am using Labview 2010 SP1 and NI DAXmq V 9.2.3f1.
The Windows Device Manager tells me "NI USB 9162 No Cartridge"
I would be glad about any suggestions 🙂
Best regards
(2,845 Views)
Hello Duncan6286,
as you can see in the following link, this combination is not supported:
http://zone.ni.com/devzone/cda/tut/p/id/8136
Please give a short feedback, if this solved your problem.
Best regards
(2,815 Views)
Thank you.
Didn't solve but at least explain it 😉
(2,809 Views)
