08-24-2011 04:57 AM
Hello
I am Nectar,
I am using NI Visa to communicate with my Evaluation Board.
The sequence that I follow to communicate is given below:
1. Create a Usb raw session
mySession = (UsbRaw)ResourceManager.GetLocalManager().Open(resources[1]);
2. I set the ControlOut method with the below parameters:
mySession.ControlOut(
Convert.ToInt16(0x80),
Convert.ToInt16(0x00),
buffer);
When I use this I get the exception with the message below:
"The value of some parameter (which parameter is not known) is invalid. VISA error code -1073807240 (0xBFFF0078), ErrorInvalidParameter"
Is there any other settings or attributes has to be done?
Is there any documentation for the C# UsbRaw class?
I searched many NI forums but not able to sort out the issue.
Please help me in this issue.
Nectar Jinil
08-25-2011 01:15 AM
Hi Nectar
Yes, there is some available documentation on C# USB RAW. I am sharing the same.
USB Instrument Control Tutorial
USB RAW Control Communication in Visual C#.NET
Feel free to revert if you have any further queries.
Krishna Prasad
