NI-845x I2C Run Script.vi got error -30742. I cannot write or read
Hi All,
I am using Labview 8.5 and Ni-8451.
I got the error coded -30742 during writing data into MCU.
It works in Cypress IIC, but using Ni-8451 it won't work.
Please help me with... Why I got this error? Any idea?
Best Thanks.
Jessie
(4,593 Views)
Greetings Cloud05
Are you using one of the LabVIEW examples for I2C scripting? Have you tried one of those? How are you configuring the I2C communication parameters? (clk speed, Volt levels and such) Finally, can you confirm the error code is -30742 and not -301742. If the latter is the case, then the problem is caused by the slave not acknowledging the master’s signal. Please reply back so that we can continue the troubleshooting process. Have a nice day.
Warm Regards,
Luis J.
Applications Engineer
(4,555 Views)
