GPIB-USB-HS Windows 7 can not load device drfiver for the hardware. The driver may be corrupted or missing Code 39
The driver is version 3.1.0,49154 and when I go to Update Driver message returns I have the most current. In NI-MAX the GPIB shows in device and instruments.
How can I get Win 7 to load the driver?
Message 1 of 9
(5,903 Views)
The latest appears to be 3.1.2. http://www.ni.com/download/ni-488.2-3.1.2/4360/en/
When do you get this message?
Message 2 of 9
(5,900 Views)
Yesterday but thanks as I will try the link you supplied
Message 3 of 9
(5,892 Views)
I did mean when as in time but when as to what program are you using when you get the error message.
Message 4 of 9
(5,889 Views)
It is in Win 7. Control Panel, System.Device Manager
Message 5 of 9
(5,880 Views)
I am still experiencing the same issue after uninstalling and installing version 3.1.0.49154 for the GPIB-USB-HS. NI-MAX shows the device but in Windows 7 Device Manage it has a yellow triangle
Message 6 of 9
(5,740 Views)
Uncle,
have you tried using the device on another PC? if so, does the device work?
additionally, have you tried installing the latest version of NI 488?
Message 7 of 9
(5,719 Views)
I tried to install on another PC and used The lastest version and all is clean in Device Manager.
Next step uninstall device and anything related to NI or VISA. Do you have any other suggestion?
Message 8 of 9
(5,688 Views)
a clean install of NI software is a good next step, and we can base further troubleshooting off of those results.
Message 9 of 9
(5,657 Views)
