Measurement and Automation Explorer ( 2 PC's via crossover)
Hello All,
I've got a problem. I connected two PC's via crossover and set up the VisaServer at the Master and configured the client at the Slave.
If the PC's are only connected via Crossover everything works fine and I can see the Masters peripherals and communicate with them.
If I now plug in the LAN-Cable and connect to the company's network too, there is a yellow exclamation Mark at the network devices in the Automation Explorer.
If I disconnect the company network and only connect the crossover everything is fine again.
I hope you can help me ... Would be great.
Greetings
Message 1 of 10
(8,256 Views)
Do you use DHCP at your company's network? Are both PC's in the same subnet? Which OS do you use for both PC's? Do you use the latest version of MAX?
Cheers,
Philip
Message 2 of 10
(8,227 Views)
DHCP is deactivated.(IPs are static) ... Yes they are in the same subnet. The OS is XP Professional. We use the MAX Version 4.6.1 and the Server version 4.6.2. Is this the latest version?
My Problem is that everything works fine ... but when I plug in the network cable to the second network adapter (Company network) I suddenly lose connection ... I can see the other PC at my Network Computers in the MAX but can't communicate with it`s peripherals. (Or sometimes there is a yellow exclamation mark).
Thank you for your help!
Greetings, Paddy
Message 3 of 10
(8,225 Views)
You wrote:
"... but when I plug in the network cable to the second network adapter (Company network) I suddenly lose connection ..." is that right? You use two network adapter in your PC?
Message 4 of 10
(8,211 Views)
Yes that's right ... We have a PC with more than one network adapter ( altogether we have got 3 adapters in each PC ).
Message 5 of 10
(8,209 Views)
Maybe you use the wrong network adaptar for your application. You can change it in MAX under devicces and interfaces. I have added a screenshot from my MAX but it's in german. Try this out.
Cheers,
Philip
Message 6 of 10
(8,202 Views)
Sorry i've forgotten the screenshot. Here it is...
Message 7 of 10
(8,201 Views)
Danke 😉 ich werds versuchen 😉
Und wir mühen uns mit englich ab 😄
Danke schonmal ... ich meld mich später wenn ichs versucht habe.
Message 8 of 10
(8,193 Views)
Okay das Problem ist gelöst.
Man muss bei Windows unter "Netzwerkverbindungen" -> "Erweitert" -> "Erweiterte Einstellungen" die Priorität der Karte über die man gehen will ganz nach oben setzen.
Vielen Dank für die Hilfe.
Gruß Paddy
Message 9 of 10
(8,173 Views)
OK. Super das es geklappt hat 🙂
Bis dann
Philip
Message 10 of 10
(8,170 Views)
