01-27-2011 04:09 AM
Hello from Greece!
I'm a new user to Labview. I'm trying to work with a camac crate with LeCroy 8901A.
While i'm using the driver functions LC8901A SRQ set.vi i get the error
1073676292 |
VI_SUCCESS_QUEUE_EMPTY |
Operation completed successfully, but queue was already empty. |
and with LC8901A SRQ Wait.vi the error
–1073807339 |
VI_ERROR_TMO |
Timeout expired before operation completed. |
I have just put the below functions in a queue
LC8901A Open --> LC8901A SRQ set --> LC8901A SRQ wait for
and I was trying to see from which slot the Look-at-Me was coming
Here is a report from NiSpy.
If somebody could help me!
Thanks anyway
R.
Solved! Go to Solution.
01-27-2011 11:41 AM
I don't know how much help I will be. I have never used the CAMAC to GPIB device before and we (LeCroy) no longer offer support for this product (It was discontinued about 10 years ago).
That said, looking at the NI-Spy file, it appears that your first error is actually a warning (A command was sent to empty a queue that was already empty) if it doesn't stop the device, it is not an issue.
The next error looks like the device was performing an SRQ and did not get any response from any instruments before the timeout.
I don't know where or how the timeout is set but it may be that the instrument did not respond to the SRQ.
Hope this helps!
Leonard Brown
LeCroy Corporation
01-28-2011 03:42 PM
Can you take a screen shot of the front panel when you run the VIs? I would like to know what values you are passing into the controls.
Jensen
01-31-2011 07:41 AM
I attached the screen shot. Hope it helps!
Regards
Rania
01-31-2011 01:19 PM
Do you have NI-VISA 1.2 installed?
02-01-2011 01:12 AM
I noticed it yesterday in this forum and I downloaded NI-VISA 4.2 for XP from the above link, with the rationale that the latest upgrade would be better than the previous.
I read the instructions from the read.html file and changed the directory for installation to C:\Program Files\IVI Foundation\VISA. I ran again the VIs and the same errors were occured.
But I can't find the installation neither in the Add/Remove Programs in the control panel nor at MAX. I can't understand what I made wrong. Isn't it supposed to find the installation there?
What can I do??
Thank you very much for your help
Rania
02-01-2011 08:37 AM
I forgot to tell you that I have the same errors in Visa Interactive Control.
I have windows XP PRo 2002 with service pack 3, ni-482.2 version 2.8, ni-Visa drivers the one i mentioned and Labview 7.1. Could it be a compatibility problem with all these versions??Or i have to install something extra??
thanks again
Rania
02-01-2011 09:40 AM
You can find information on compatibility for Labview here, and for drivers in the read me document on the download pages.
Labview 7.1 is compatible with Win XP.
NI-488.2 2.8 compatibility here. It looks like version 2.4 will work for you.
There could be problems if you installed this driver over NI-488.2 driver earleir than version 2.0
This driver allows upgrades starting from NI-488.2 for Windows, Version 2.0, on Windows XP. To install over software lower than Version 2.0 on Windows XP, you must uninstall the lower version first. To uninstall on Windows XP, go to the Control Panel and select Add/Remove Programs.
And it is not compatible with Labview 7.1
This driver version is recommended for use with the following software:
NI-VISA 4.2 compatibility here.
I didn't find anything conflicting here.
See if getting all of the compatible software gets rid of the error, and let me know if the issue persists.
02-01-2011 09:44 AM
This is for MAX System Information
Operating System(OS) Microsoft Windows XP Professional
OS Version 5.01.2600
OS Info Service Pack 3
Processor Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz / x86 Family 6 Model 15 Stepping 6 / GenuineIntel / 1868 MHz
Number of Processors 2
Physical Memory 1.99 GB of RAM
Drive C:\ 446 GB of 465 GB free
National Instruments Software: Version:
CVI 5.5
CVI Run-Time 9.1.0.428
NI-DAQmx 8.7.1f3
NI-488.2 Software 2.80
IVI Compliance Package 3.1
LabVIEW 7.1
Advanced Analysis 7.1.0
Application Builder 7.1.0
Measurement & Automation Explorer 4.7.1f8
Measurement Studio Visual Studio 2005 Support - See individual versions below.
NI-USI 1.0.2
NI PXI Platform Services 2.5.6
NI-PAL Software 2.5.4
NI LabVIEW SignalExpress 2.5.1
NI Spy 2.7.2.49152
NI System Configuration 1.1.1f5
NI-VISA 5.0
NiVisaServer.exe 4.2.0.49153
NIvisaic.exe 5.0.0.49152
NI-VISA Runtime 5.0
LabVIEW Run-Time 8.0.1 8.0.1
LabVIEW Run-Time 8.2.1 8.2.1
LabVIEW Run-Time 8.5.0 8.5.0
LabVIEW Run-Time 2009 SP1 9.0.1
02-01-2011 10:27 AM
It looks like you need to get to get labview 8.6 or newer, or you need to get ni-visa 4.2, and ni-488.2 2.4
