Link VISA library with Qt
I’m developing a GUI with Qt to control some oscilloscopes from LeCroy. For communication via Ethernet I want to use the VISA library.
I’ve written some code to test the communication channel but it just won’t compile. Here a short list of what I’ve already tried to make it run:
- copied project to C:\Temp to avoid space problems within the path
- used visa32.lib and visa64.lib
- copied libraries to the project folder
- linked libraries static and dynamic
The result or the copied library into the project folder is:
Fehler: No rule to make target 'C:/path…', needed by 'debug\KommunikationOszi3.exe'. Stop.
And the result with the “original” library is:
Fehler: error: Files/IVI: No such file or directory
Fehler: error: Foundation/VISA/Win64/Lib_x64/msc/: No such file or directory
The link commands in the project files are:
 lib within project folder
win32: LIBS += -L$$PWD/ -lvisa32
INCLUDEPATH += $$PWD/
DEPENDPATH += $$PWD/
lib in the original folder:
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc/ -lvisa32
else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc/ -lvisa32d
INCLUDEPATH += $$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc
DEPENDPATH += $$PWD/../../Program Files/IVI Foundation/VISA/Win64/Lib_x64/msc
And some code examples from my program:
Header file of the oscilloscope class
#ifndef LECROYWAVESURFER_H
#define LECROYWAVESURFER_H
#include <string>
#include <sstream>
#include <iomanip>
#include "visa.h"
class LeCroyWavesurfer
public:
    LeCroyWavesurfer(ViSession *defaultRM, std::string name = "", std::string ip = "0.0.0.0");
    ~LeCroyWavesurfer();
    // communication functions
    void write(std::string command, std::string logMsg);
    std::string read(std::string command, std::string logMsg, ViUInt32 datLength);
    // configuring oscilloskop
    void autoSetup(std::string channel);
private:
    std::string name;
    // for VISA-communication
    ViSession *defaultRM;        // connection to main VISA driver
    ViSession session;          // connection to device
    ViStatus status;            // communication status
    ViUInt32 retCount;          // retur count from string I/O
#endif // LECROYWAVESURFER_H
Some extracts frome the CPP file of the oscilloscope class
#include "leCroyWavesurfer.h"
// Includes for code completion
#include <QDebug>
// Constructor
LeCroyWavesurfer::LeCroyWavesurfer(ViSession *defaultRM, std::string name, std::string ip)
    this->name = name;
    this->defaultRM = defaultRM;
    qDebug() << "Connection to Wafesurfer" << name.c_str();
    std::string geraet = "VICP::" + ip;
    status = viOpen(*defaultRM, (ViRsrc)geraet.c_str(), VI_NULL, VI_NULL, &session);
    if (status < VI_SUCCESS) qDebug() << "Connecting to" << name.c_str() << "failed";
    qDebug() << "Setting time out for communication with" << name.c_str();
    status = viSetAttribute(session, VI_ATTR_TMO_VALUE, 500);
    if (status < VI_SUCCESS) qDebug() << "Setting time out failed";
// Destructor
LeCroyWavesurfer::~LeCroyWavesurfer()
    qDebug() << "Disconnecting from" << name.c_str();
    status = viClose(session);
    if (status < VI_SUCCESS) qDebug() << "Disconnecting from" << name.c_str() << "failed";
    delete this;
// Writing command to oscilloscope
void LeCroyWavesurfer::write(std::string command, std::string logMsg)
    // creating log message for debugging
    qDebug() << logMsg.c_str();
    qDebug() << "Sent command:" << command.c_str();
    status = viWrite(session, (ViBuf)command.c_str(), command.length(), &retCount);
    if (status < VI_SUCCESS) qDebug() << logMsg.c_str() << "failed";
// activating auto setup for chosen channel
void LeCroyWavesurfer::autoSetup(std::string channel)
    // command syntax: <channel> : Auto_SETup [FIND]
    // <channel> : = {C1, C2, C3, C4}
    // If the FIND keyword is present, gain and offset adjustments will be performed
    //  only on the specified channel.
    // In the absence of the FIND keyword, the normal auto-setup will be performed,
    //  regardless of the <channel> prefix.
    std::string command = "C" + channel + " : Auto_SETup FIND";
    std::string logMsg = "Setting auto setup for channel " + channel;
    write(command,logMsg);
Qt 5.2.1 runs under Win7. I have a user account not an admin account.
Does anyone know how to fix this problem?
(12,542 Views)
Accepted by Munin
I don't know why, but with a direct path it works. Should look like this:
# Library for VISA functions
win32: LIBS += "C:/Program Files (x86)/IVI Foundation/VISA/WinNT/lib/msc/visa32.lib"
If you also add the include folder you don't need to copy the visa.h into your project folder.
INCLUDEPATH += "C:/Program Files/IVI Foundation/VISA/Win64/Include"
DEPENDPATH += "C:/Program Files/IVI Foundation/VISA/Win64/Include"
(12,400 Views)
BRO you saved me XD
(3,195 Views)
