‎04-22-2009 12:05 PM
I am so new with labview, I downloaded the 4294A driver and I was wondering if anyone already developed a personal code to perform measumerment.
any help would be appriciated.
‎04-22-2009 12:29 PM
‎04-22-2009 11:49 PM
I did try them, none of them answers what I am looking for, I want to sweep the frequency and read the measured impedance and save it in to a file,
‎08-07-2018 07:28 AM
It's almost been a decade but I have a code that is just what you want! 🙂
‎10-30-2020 03:40 AM
Hello everyone
i am working to make a software for my agilent 4294a by labview.
but as i see it is very easy to make sweep measurements.
but it is limited up to 801 point therefore i need more points instead.
but i could not make single point measurements so that i can control it by computer for very huge points.
is there any way to increase the number of points from 801 to more, or any way to make single point measurements?
‎10-30-2020 05:55 AM
‎10-30-2020 06:12 AM
thank you for your answer
i know but if i could do it by single point it would be more easy
as i see i cannot do it by single measurement.
‎10-30-2020 09:32 AM
‎11-02-2020 10:17 AM
The 4294 is an old model, it has only 801pt memory for a sweep. There's no way around that!
So like Albert said, build separate sweeps and perform each in sequence.
Post your code if you get stuck and we can help.
Craig
‎11-13-2020 01:40 AM
Thank you İ am able to make sweep measurements.
so i do not need any help.
best regerds.
