Error GPIB interface
I use a NI PCIe-6509 for connecting some keithley instruments to PC W10. Unfortunately, after an automatic PC update, GPIB doesn't work properly anymore. Attached the error I get by "Test panel" of NI MAX software. Any suggestion to solve the problem?
Thank you
Chiara
(859 Views)
Hello Chiara!
In MAX, go to TOOLS >> Reset Configuration Data. This will remove all of your devices and settings from MAX and will reset the database file. Afterwards, restart your computer and see if you can use your device.
Hope this answers your question!
(824 Views)
I doubt that.  A PCIe-6509 is a static DIO card.  It has nothing to do with GPIB.
(821 Views)
