How to get data in serial communication
Thanks for the reply.
Do I press the SEND button instead of the arrow button in the upper left corner to run it?
Also, do I need to make the online part glow as well?
I'm sorry for asking so many questions.
When I run the program, nothing appears in the read indicator.
Thank you for the program to convert the temperature to decimal.
Thank you very much for the temperature conversion program.
I'm sorry for asking again and again.
I would like to know how to continuously send only the "DATA¥r" command to the instrument to acquire data.
Translated with www.DeepL.com/Translator (free version)
Message 21 of 24
(521 Views)
Thanks for the simplification!
I'm getting the error "Memory or data structure is corrupt".
What could be the cause?
Message 22 of 24
(519 Views)
sorry , no manual....
1. start the vi by click on the run arrow top left menu
2. set the com port and serial parameters
3. click on Online , it will indicate bright green
4. change the Read and Write display mode .. enter the commands as shown in my pic
5. hint the send button according to the commands you want to send
... to finish hit exit
if you don't know the com port number and you have a USB connector, you can try Refresch in the Resource Name pull down and have a look before and after plug in the USB ...
Greetings from Germany
Henrik
LV since v3.1
Message 23 of 24
(510 Views)
I did as you explained, but it didn't work.
I'm sorry for all the explanations you gave me!
Message 24 of 24
(500 Views)
