Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
03-17-2005 07:57 AM
03-18-2005 02:37 PM
03-15-2006 05:52 AM
03-15-2006 07:10 AM
Take an example from all the hardware examples already available in LabVIEW.
goto help/find examples/hardware input and output/DAQMX/Analog input/Voltage measurement
and select one that you like
I suggest to start with Acq&Graph Voltage-Int Clk.vi
To my surprise is the alpahbetical listing here crazy to give help to beginners
03-16-2006
07:01 AM
- last edited on
11-16-2025
04:02 PM
by
Content Cleaner
Hi Justinas,
The PCI-MIO-16XE-10 is compatible with the latest NI Data Acquisition devices -- NI-DAQmx 8.0. Once the drivers and device are installed correctly, you can test to make sure everything is working correctly in Measurement & Automation Explorer (MAX). In MAX, expand Devices and Interfaces>NI-DAQmx Devices to see your device. Once you select the device, you can view test panels for it to make sure that it is working correctly.
As the previous user said, the NI-DAQmx Examples are probably the best place to start. In LabVIEW, go to Help>Find Examples. In the Window that appears, select Hardware Input and Output>NI-DAQmx to see a list of all the examples available to help get you started. The description on the right will help you determine which example is a good starting point. Also, take a look at the link below for a short introduction to DAQmx.
Learn 10 Functions in NI-DAQmx and Solve 80% of Data Acquisition Applications
03-16-2006 07:42 AM
04-05-2006 10:31 AM
04-06-2006 11:15 AM
Hello Justanas,
In order to change from the TBX-68 accessory to the SCB-68, expand Devices and Interfaces in MAX, right-click on your PCI-MIO-16XE-50 and choose Properties. Switch to the Accessory tab and choose SCB-68 from the list. Then, when you create your NI-DAQmx Task or global channel and look at the connection diagram, you will see this accessory and you can see how to connect your signals.
The terminals you referenced indicate that you are setting up your task for AI0 to be NRSE and your task for AI1 to be differential which is fine. Since you are doing a current measurement on AI0, be sure to correctly setup your shunt resistor and its value.
Laura
04-26-2006 05:28 AM
04-26-2006
10:18 AM
- last edited on
11-16-2025
04:02 PM
by
Content Cleaner
Hi Justinas,
That error tells you that the operation you are trying to do, such as analog input, is already being used somewhere else. You can only have one analog input task at a time, so you cannot run both the analog input test panel and a program that does analog input at the same time. You can read in more detail about this error in this knowledgebase article.
Laura
