08-12-2009 07:40 AM
I have a big problem with the driver XANXDC for Xantrex xdc 30-200 alim since few days, I can't connect my alimentation with my program, I choose a VI gave with the driver (getStarted), but there is an error, I would test the RS 232 connection to be sure that all it's ok, with an hyper terminal, but I don't know how to perform, I have never do this before...
Someone could help me please?
08-12-2009 09:14 AM
You can get quite a ways by using windows help and once you launch Hyperterminal, it's help.
Start>Programs>Accessories>Communications will start Hyperterminal. After clicking through the modem/phone line questions, you are prompted for a name. Enter whatever you want. You will then be prompted for the com settings. Make absolutely sure that what you enter matches the instrument settings. The instrument settings will be documented in it's manual.
You connected and you can start typing commands. Try a command that you know the instrument should return something. AS I HAVE ALREADY MENTIONED, if you get nothing, then you need to check the com settings and cable. Verifying that the instrument has it's com port enabled is also a good idea. I also recomended that you use an ohmeter to check the cable. Have you even done that simple task? The manual should explain what type of serial cable to use. If it does not, then contact the vendor to get this vital piece of information. Nothing will work if you are using the incorrect cable type.
08-12-2009 09:29 AM
08-12-2009 09:45 AM
08-12-2009 09:48 AM
Yes I have understand...
The xantrex need a null modem cable.
08-12-2009 10:15 AM
I have test my cable to see if it was a null modem or a straigh through cable, I follow this schema:
http://digital.ni.com/public.nsf/allkb/1EE0DD8AF67922FA86256F720071DECF
I took the next connector like if it was the femal connector and the other on the right the male connector.
If I follow my cable, with the schema before, my cable it's not a null modem and not a straigh through 😐
For the pin I have:
fem mal
1---->5
2---->4
3---->3
4---->2
5---->1
08-12-2009 10:41 AM
