35660A -Command requires GPIB Controller to be Controller in Charge
Hello
 I am trying  to read and writeHP 35660A siganl Analyzer through a GPIB.
This same VI worked with another signal analyzer , but with this one it shows 2 error msgs.. see atchements.
any ideas?
Nghtcwrlr
(3,906 Views)
If the program works with another 35660A, then I would suggest you check to see if the firmware on both models are the same.
(3,899 Views)
Hey Dennis
 I think the GPIB interface of this device is defect. Cos i tried to connect another signal analyzer with the same cable and its been recognized by the Measurement and automation.
So am planning to change to the other analyzer.
Thankss
Nghtcwrlr
(3,875 Views)
Hi
Certain function resquies that GPIB board to be the CIC (Controller In Charge). That could be your issue. Look at the following kb
- What Is the CIC Protocol in GPIB?
- GPIB Error Codes and Common Solutions (Part 1)
Best regard
Nick
(3,864 Views)
