Help understanding this manual VISA write command
, The hardware manual says:
undefined
What does this look like on labview, right now I have it looking like this for a Z command is it correct:
undefined
(3,706 Views)
The attached snippet should be what you are looking for.  It would be helpful in the future if you stated exactly what hardware you are trying to communicate with.
(3,704 Views)
It's just a gas sensor that outputs over serial. How did you get that little n next to the Z? and  the concatenated string goes straight ot the visa write block yes?
(3,701 Views)
If you right click the string constant and select Visible Items > Display Style it will indicate what display style it is configured for.  You can then left click the constant to change the display style .
(3,696 Views)
I would advise against using the End Of Line Constant since it is platform dependent.  Use an actual string constant with "\r\n" when in "\ Codes" display.
GCentral
(3,686 Views)
