em 05-18-2016 07:48 AM
, The hardware manual says:
What does this look like on labview, right now I have it looking like this for a Z command is it correct:
05-18-2016 08:26 AM - editado 05-18-2016 08:27 AM
The attached snippet should be what you are looking for. It would be helpful in the future if you stated exactly what hardware you are trying to communicate with.
em 05-18-2016 08:29 AM
It's just a gas sensor that outputs over serial. How did you get that little n next to the Z? and the concatenated string goes straight ot the visa write block yes?
em 05-18-2016 08:35 AM
If you right click the string constant and select Visible Items > Display Style it will indicate what display style it is configured for. You can then left click the constant to change the display style .
em 05-18-2016 10:58 AM
I would advise against using the End Of Line Constant since it is platform dependent. Use an actual string constant with "\r\n" when in "\ Codes" display.
