05-12-2011 08:30 AM
I've been using Lab Windows for about 17 years now. For the most part I communicate with measurement instruments via GPIB, I've written a GPIB module that uses asynchronous call backs and speaks to a multitude of instruments. Still, once in a while, a glitch occurs on a long test and communications fail. I'd like to write some routines to correct errors. I'm sure GPIB has many more capabilities than what I'm using. Is there a place where I can really learn everything there is to know about GPIB?
05-13-2011
02:34 PM
- last edited on
02-03-2026
11:24 AM
by
Content Cleaner
It sounds like you may be more experienced than this but a good starting place is this tutorial about GPIB.
If that is not low level enough for you I would suggest studying the protocol itself IEEE 488.2.
Hopefully, that provides the information you want.
