10-04-2023 04:35 PM
10-05-2023 09:44 AM
NI MAX is only for NI Devices. If you can see the device in Windows Device Manager and there are no errors, then the device is installed properly. You should be able to configure the GPIB device in the Keysight software you installed.
If you are using LabVIEW with your devices, you do not need to use NI MAX. You will need to install the drivers for the Maury Tuner to interface with LabVIEW.
Maury Tuner LabVIEW drivers
How can I make NI LabVIEW communicate with my 82357A USB/GPIB Interface?
Maury Microwave Software Download Site
Hope this helps you and your colleague with this project.
10-06-2023 01:42 AM
If you use VISA Passport Keysight's GPIB will appear in NI MAX.
However, there are some restrictions.
[How to use]
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHh0CAG
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHcyCAG
https://edadocs.software.keysight.com/kkbopen/io-ni-gpib-keysight-gpib-589315082.html
