VBA USB control example
You will have to excuse me but I really new at this,
With this example uses GPIB
I want to do the same thing with a USB interface instrument:
How would the below program change?
Public RM As VisaComLib.ResourceManager 'Resource manager
Public PS As VisaComLib.FormattedIO488 'IO Object
Private Sub CommandButton1_Click()
Set RM = New VisaComLib.ResourceManager 'Resource Manager Object created
Set PS = New VisaComLib.FormattedIO488 'FormattedIO488 Object created
Set PS.IO = RM.Open("GPIB0::12::INSTR") 'IO Object created (enter VISA address of ENA)
PS.IO.Timeout = 10000 'Timeout time in msec
PS.WriteString ("*IDN?")
Sheet1.Cells(6, 2) = PS.ReadString
PS.IO.Close
Set PS = Nothing
Set RM = Nothing
End Sub
(2,465 Views)
You can also use it by simply changing the address field of your code.
If you want to do something advanced, please do as below.
Sub communication_test1()
    Dim RM As VisaComLib.ResourceManager
    Dim VISACOMOBJ As VisaComLib.FormattedIO488
    Dim addr As String, list() As String
    Dim timeout As Long: timeout = 5000 '5000msec
    addr = "GPIB0::15::INSTR" 'GPIB Resource Name
    'OR
    addr = "USB0::0x****::0x****::********::INSTR" 'USBTMC Resource Name
    Set VISACOMOBJ = New VisaComLib.FormattedIO488
    Set VISACOMOBJ.IO = RM.Open(addr, NO_LOCK, timeout)
    With VISACOMOBJ
        .IO.timeout = timeout
        .WriteString "*IDN?" & vbLf, True
        list = .ReadList(ASCIIType_BSTR, ",")
        .IO.Close
    End With
    MsgBox Join(list, vbLf)
End Sub
Sub communication_test2()
    Dim igpibDev As VisaComLib.igpib 'for GPIB
    Dim iusbDev As VisaComLib.IUsb ' for USB
    Dim ilanvxi11Dev As VisaComLib.ITcpipInstr 'for VXI-11(LAN)
    'OR
    'OR
    addr = "TCPIP0::*.*.*.*::inst0::INSTR" 'VXI-11 Resource Name
    Select Case VISACOMOBJ.IO.HardwareInterfaceType
        Case VisaComLib.HardwareInterfaceType.INTF_GPIB
            Set igpibDev = VISACOMOBJ.IO
            With igpibDev
                .timeout = timeout
                .ControlREN GPIB_REN_ADDRESS_AND_LLO
                MsgBox "The measuring instrument has been locked out." & vbLf & "The instrument should be in a state where it does not accept any button operations other than the power supply." & vbLf & "Try pressing any buttons."
                VISACOMOBJ.WriteString "*IDN?" & vbLf, True
                list = VISACOMOBJ.ReadList(ASCIIType_BSTR, ",")
                .ControlREN GPIB_REN_GTL_AND_DEASSERT
                MsgBox "The lockout has been released."
            End With
        Case VisaComLib.HardwareInterfaceType.INTF_USB
            Set iusbDev = VISACOMOBJ.IO
            With iusbDev
                .timeout = timeout
            End With
        Case VisaComLib.HardwareInterfaceType.INTF_TCPIP
            'Note that INTF_TCPIP is not always VXI-11, but sometimes HiSLIP or Socket (identified by address)
            Set ilanvxi11Dev = VISACOMOBJ.IO
            ilanvxi11Dev.timeout = timeout
    End Select
    VISACOMOBJ.IO.Close
End Sub
(2,418 Views)
