GPIB-USB-HS
Neither of the lights (Ready and Active) are glowing while the cable is connected to a computer USB slot. I opened the device and the supply voltage to the PCB board from USB cable is not 5 volt DC (it was around 3.1 V DC).
So my question is not getting the enough supply voltage (which is 5 VDC) be the reason for not glowing any light or not?
(768 Views)
That could be your computer's USB not outputting enough power, which I have had problems with, especially on laptops. I generally make sure to use an externally powered USB hub if I must use USB for instrumentation.
The other possibility is something on your GPIB-USB-HS is broken and is drawing too much current.
My first thing to try here is to plug the device into a different computer and see if it works.
(753 Views)
I checked the USB supply voltage is satisfactory 5 VDC.
When USB is connecting to PC port the lights are flashing momentarily and after that there is no response or light.
(Note: I checked this to a seperate PC where no software or driver is loaded. I was expecting to get a pop window from PC for "found a new hardware wizard" - but nothing was appeared in the PC). Please find the attached 6 second video of light flash.
(708 Views)
With reference to my previous posts, I like to inform you that I am using this for Agilent AAS instrument.
Please help me to understand whether this problem is due to driver? Or the adapter hardware is already damaged/broken?
Thanks & Regards,
Mainak Das
(683 Views)
You need to tell us more about your problem, and what you have tried to fix.
For example:
  • Do you see the device listed in Windows Device Manager?  (Is there an X beside its name?  Look at the details for the device.)
  • Did you install the NI-488 driver software?
  • Can you see the device listed in NI-MAX before the lights turn off?
  • Have you tried this device with another computer?
More details usually results in better help.
Craig
(645 Views)
Do you see the device listed in Windows Device Manager? No
Did you install the NI-488 driver software? - Yes
Have you tried this device with another computer? - Yes
I concluded with the fact that the board(USB-IEEE adapter is broken and needs to be replaced.
My question is how such a costly item get damaged within 8 months? Is it due to voltage supply problem from SMPS power supply from CPU?
(584 Views)
