02-27-2009 03:02 PM
I am looking to see if anyone has ever used anything like this and if so can anyone recommend anything? Thanks for any feedback.
02-27-2009 03:22 PM
We have used the PCMCIA to serial card located:
http://www.quatech.com/catalog/rs232_pcmcia.php
Specifically the QSP-100. I have not programmed applications using it but have successfully used it with other companies application software.
Hope this helps.
02-27-2009 03:27 PM
Thank you for the feedback. That is something I will look into. I am looking for both a PCMCIA option as well as a USB or RS232 option (in case the laptop bites it while in the field I will need a way to get four serial ports out of the field PC, preferrably plug and play).
Thanks!
02-27-2009 03:28 PM
02-27-2009 03:32 PM
