Showing results forĀ
Search instead forĀ
Did you mean:Ā
Four Port Serial Switch
I am looking to see if anyone has ever used anything like this and if so can anyone recommend anything?  Thanks for any feedback.
(4,220 Views)
We have used the PCMCIA to serial card located:
http://www.quatech.com/catalog/rs232_pcmcia.php
Specifically the QSP-100. I have not programmed applications using it but have successfully used it with other companies application software.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,215 Views)
Thank you for the feedback.  That is something I will look into.  I am looking for both a PCMCIA option as well as a USB or RS232 option (in case the  laptop bites it while in the field I will need a way to get four serial ports out of the field PC, preferrably plug and play).
Thanks!
(4,211 Views)
Accepted by jon_mcbee
Never used that. For multiple serial ports, this is what I've used.
(4,210 Views)
Thank you Dennis, this may be just what I am looking for!
(4,207 Views)
