02-21-2012 11:42 AM
I have some LabVIEW code that will call the VISA Open function and the VISA Map Trigger Function. I receive the error code - 1073676414 warning message saying that the resources are already mapped. This is an intermittent occurrence after each time I execute the LabVIEW code. I make sure to unmap those trigger lines upon exiting the application. How do I solve this issue? Thank you in advance for your time and consideration.
02-22-2012 12:09 PM
What hardware are you using? Is there a rate at which you are executing the trigger function i.e. in a loop? How are you executing the code?
Patricia B.
