05-08-2009 04:01 AM
I also got error 0x4000FFC2 as negative.
I get it in an application to send firmware to TMS320C2000 through RS232.
The reason is that for each byte I send, I get the same byte in response.
BUT, not the last byte. I get no response from it, which creates this error. So I did as you did, I remove this particular warning.
01-16-2012 03:41 PM
I can also confirm that setting the buffer size using the VISA Set I/O Buffer VI fixed my problem interfacing with a USB to serial converter.
Thanks Jim!
