Continuous Serial Write and Read
Hi all,
I'm running the example Continuous Serial Write and Read.vi in National Instruments\LabVIEW 2021\examples\Instrument IO\Serial. But i don't know how to pass the string format to command ?? can you help me
Message 1 of 8
(4,005 Views)
What exactly are you trying to send?  You can change the display format of the control to \ Codes or Hex if you need to send non-ASCII characters.
Message 2 of 8
(3,977 Views)
Thank you,
I run command on Tera Term ok but i don't know how to run on labview (how to pass commands ?)
Example:
I run on Tera Term command:   _ *****[CR[LF]  -> Output:   ******
I run on Labview i convert  _ *****[CR[LF] to ascii but output is not the same as above
Please help me
Message 3 of 8
(3,967 Views)
Please send the vi. But first fill in what you want to send in the string an then via edit/make all values default , can be make current values default. And finally save the vi and then send the vi.
You do something wrong with that string and what you typed above is wronv anyway.
Message 4 of 8
(3,955 Views)
File .vi I attach below. Please check help me.
I pass to command 66128531\n -> response same as command but I expect a different response.
I expect response same as response on tera term.
Message 5 of 8
(3,934 Views)
I attach file .vi below.
I pass to command 66128531\n then response same as command but I expect a difference response.
I expect response same as on tera term.
Message 6 of 8
(3,940 Views)
Accepted by kiendo
Hi
I have set the string to display in \ mode to see your escape and also the correct \n
I fact I removed one \ before the n.
You could have used return instead.
attached the modified file.
Message 7 of 8
(3,931 Views)
Great! Thank you so much!
Message 8 of 8
(3,927 Views)
