Code for FAST 2
I have read the manual,there are 2 commands ERRS,ESR.
There is a vi for ESR and one for ERRS.Both are used in my code.So now tell me what change is appropriate.
Message 41 of 91
(3,614 Views)
If you want to read the error status register, it is ESR?
Message 42 of 91
(3,607 Views)
I guess at this point I've lost track of what is and isn't working for you. So, here's a checklist, and if you could please indicate which steps worked and which didn't:
1) Send command over RS232 to instrument from MAX (no response required). Change the frequency or something like that.
2) Send query from MAX and receive response. *IDN? is the usual test string.
3) Send command to instrument from LabView. Instrument executes command. Again, change the oscillator frequency.
4) Send query from LabView and receive response. Again, send a *IDN? and look at the response string.
Have you successfully executed all four steps? If not, there's no point in trying to diagnose the details of why reading a particular status register byte isn't working.
Message 43 of 91
(3,603 Views)
As per the original driver SW from ni webpage,the Single Parameter vi has both ESR and ERRS.
I am taking it as such,as i feel there is no change required.
The only change which i suppose is making it compatible with serail comm.
Deleting a Vi(ESR/ERRS),whether this is required???If so,does it not give further error??
Message 44 of 91
(3,601 Views)
I already Queried for IDN from MAx,Labview.I got the responsse too.
Message 45 of 91
(3,599 Views)
If you send the string 'SNAP? 1,2', what comes back?
Message 46 of 91
(3,597 Views)
Thanks for your response.They closed the lab just now.I can try with this command and let share the response here by tomorrow.
Thanks for your continued support.
Message 47 of 91
(3,585 Views)
I tried with SNAP? 1,2,i was able to read X,Y values.
I tried with a Basic Serial Write and Read.vi.
May i know what exact changes in required in Stanford Research 830 Acquire Measurement - 1 Parameter.vi to get Serial data comm. with proper response for the commands??
Message 48 of 91
(3,544 Views)
Please reply to me previous post and also to this.
Why there is always a TimeOut error when ESR is queried.20bytes are read,as mentioned in the driver.
I change it to Read bytes from Port,which also throws error.
Whats the issue here and how to fix??
Message 49 of 91
(3,495 Views)
The most recent version of your error-query routine that you posted ('more_change.png' on July 13th) uses the Bytes At Port property. Did you follow Dennis's advice about eliminating that and using a proper termination character instead?
Similarly, if you use the Basic Serial Read Write command to query the status and error registers, do you get a sensible string back?
Message 50 of 91
(3,484 Views)
