Can i use the "serial break function (Visa or Compatible)" with a PCI-485 Board ?
I need a "RS232" datastream with 8N2 at 250k Baudrate for a RS485n Interface (DMX512). The Problem is i need a "serial Break" at the start of the datastream. So i want do know if it is possible to send a "break signal" with the PCI-485 like i do it with my normal "Uart - built in Rs232 in my PC".
Thanks for any information
Mario
(3,813 Views)
Any serial communication that the UART controls (stop bits, data bits, breaks, etc.) will be the same between NI's RS-232 and RS-485 interfaces. As for other brands, I don't see why serial break wouldn't be supported, but you would have to verify that with the manufacturer.
(3,813 Views)
