ATS-1
Has anyone used the Audio Precision ATS-1 Access Audio test system, I am atempting to set the unit to Ratio A / G ?
Hope some pone can help.
(5,650 Views)
Hi Cally,
Good Morning and I hope your well today.
Thanks for your post concerning how to set the unit Ratio A/G.
Using the ni.com/idnet (Instrument Device Network) I can see the Audio Precision do have a driver from the ATS-1. Are you using this?
However, I am sure your aware you can simply write your own code in LabVIEW using GPIB/VISA commands as the ATS-1 has a GPIB interface. You must remember to install NI- VISA and NI-488.2 (GPIB) Drivers to use these VIs in LabVIEW.
From the Audio Precision website I can see they have an ATS-1 GPIB Programmer's Reference Manual and ATS-1 User Manaul. The reference manual for programmers should give you a list of the commands and what they do. These are the same commands their driver will use. I wonder if there is a command in the manual? I am afraid I currently can't access these manuals as I don't have a log-in. But if you do have these materials, I'd be more than happy to take a look through to help you find out if you can/and how to set the unit to ratio A/G.
If you are new to LabVIEW or GPIB/VISA in LabVIEW you can find some simple examples in the NI Example Finder (Help>>Find Examples..) and search for GPIB. You must use the correct address.
How Do I Fix Error: 1073807265 occurred at VISA Write
This knowledgebase explains how to find the instrument address of your GPIB Card.
Why Can I Not See My GPIB Card In MAX? [broken link removed 2/25/26]
Troubleshooting if you can't see the GPIB card in Measurement and Automation Explorer (MAX)
 If your not using an NI GPIB Board then make sure you enable 488.2 support.
I hope this advice finds you well and Please let me know your thoughts,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,635 Views)
Hi Cally,
Good Morning and I hope your well.
I noticed you've visited the site since I responded to your post.
I was wondering if you need any more support with your application?
Kind Regards
James Hillman
(5,617 Views)
Hi Hillman,
Thanks for your support, I am now controlling the ATS-1 via VISA.
C
(5,588 Views)
Hi Cally,
Thanks for the update - I am glad you've got it all working.
Iwas wondering if you'd consider posting your code for future users?
Kind Regards
James Hillman
(5,586 Views)
Hi Cally,
I am use gpib to control ats-1 too,   can u share your code .
Tks!
L
(4,877 Views)
