ATS-1
Has anyone used the Audio Precision ATS-1 Access Audio test system, I am atempting to set the unit to Ratio A / G ?
Hope some pone can help.
(5,231 Views)
Hi Cally,
Good Morning and I hope your well today.
Thanks for your post concerning how to set the unit Ratio A/G.
Using the ni.com/idnet (Instrument Device Network) I can see the Audio Precision do have a driver from the ATS-1. Are you using this?
However, I am sure your aware you can simply write your own code in LabVIEW using GPIB/VISA commands as the ATS-1 has a GPIB interface. You must remember to install NI- VISA and NI-488.2 (GPIB) Drivers to use these VIs in LabVIEW.
From the Audio Precision website I can see they have an ATS-1 GPIB Programmer's Reference Manual and ATS-1 User Manaul. The reference manual for programmers should give you a list of the commands and what they do. These are the same commands their driver will use. I wonder if there is a command in the manual? I am afraid I currently can't access these manuals as I don't have a log-in. But if you do have these materials, I'd be more than happy to take a look through to help you find out if you can/and how to set the unit to ratio A/G.
If you are new to LabVIEW or GPIB/VISA in LabVIEW you can find some simple examples in the NI Example Finder (Help>>Find Examples..) and search for GPIB. You must use the correct address.
How Do I Fix Error: 1073807265 occurred at VISA Write
This knowledgebase explains how to find the instrument address of your GPIB Card.
Troubleshooting if you can't see the GPIB card in Measurement and Automation Explorer (MAX)
 If your not using an NI GPIB Board then make sure you enable 488.2 support.
I hope this advice finds you well and Please let me know your thoughts,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,216 Views)
Hi Cally,
Good Morning and I hope your well.
I noticed you've visited the site since I responded to your post.
I was wondering if you need any more support with your application?
Kind Regards
James Hillman
(5,198 Views)
Hi Hillman,
Thanks for your support, I am now controlling the ATS-1 via VISA.
C
(5,169 Views)
Hi Cally,
Thanks for the update - I am glad you've got it all working.
Iwas wondering if you'd consider posting your code for future users?
Kind Regards
James Hillman
(5,167 Views)
Hi Cally,
I am use gpib to control ats-1 too,   can u share your code .
Tks!
L
(4,458 Views)
