Industrial Communications
How can I connect PLC to PC (LabVIEW) using OPC Server with MPI
Dear Consultant,
I have a PLC S7-300 with 313C CPU and I want to connect it to LabVIEW using OPC Server with MPI cable USB. On device manager the cable detected as Simatic USB, meanwhile on OPC Server it detected as COM1. How can I change it so that the PLC and communicate with the PC
Urielhakim
(4,911 Views)
I have encountered the same problem.
(4,854 Views)
have you done with your connection? if you have it mind to share it with me? i really need this connection
(4,827 Views)
So sorry to reply this after along awaited time. I encounter a hard phase of my bachelor thesis with my kinetics equation.
Okay, I have figured it out about the issue. I use RS232 adapter for DP/MPI Network and then connect it with  USB to Serial Converter. It's quite helping though. But it can not being used to download the program to PLC. You need to use the original cable for downloading the program. I hope its helping. And so sorry for the late reply.
(4,665 Views)
