Hobbyist Toolkit
Running startup.rtexe on Raspberry Pi
I am using LV2020 with the LINX toolkit installed from VIPM. I have a vi that will toggle a digital line which is connected to an LED. When I run the vi in development, everything works and my LED will blink. I can build the vi into a startup.rtexe and run it a startup without any problems. However, my program is not running because the LED does not blink. I have provided screenshots of the version of software I am using and what is installed on the pi.
Any ideas on why the rtexe is not running?
(4,669 Views)
To clarify, your code works without a GUI, correct?  Code running on a Raspberry Pi does not have a GUI.  The GUI will work when you run the VI in development but not when deployed.
Also, can you clarify what you mean by build a startup.rtexe?  I assume you are trying to deploy your code to the Raspberry Pi through a LabVIEW project and telling it to run on startup.  If this is not what you are doing please clarify.
David Wilt
The New Standard LLC
(4,663 Views)
My code works without a GUI. Yes, I am trying to deploy my from the build spec in my project.
(4,660 Views)
Accepted by ss52642
I think I have figured it out. The version of labview I am using is 2020 but not SP1. I copied my project over to a computer with LV2020 SP1 and I was able to build and deploy my startup.rtexe from the project.
(4,656 Views)
Interesting ... I am not sure why that would resolve your issue.
David Wilt
(4,650 Views)
I have same problem, and my labview version is NI LabVIEW 2020 SP1 (32-bit), still has save problem, very strange.
(3,523 Views)
