Hobbyist Toolkit
Linx executable for Arduino not working
hi
I created a simple blink program executable with linx for arduino uno but the standalone application isn't working. Does linx support standalone executable?
thank you
Message 1 of 12
(4,257 Views)
Yes, LINX supports converting your code into a executable.
To understand your issue more details need to be provided as to what you are doing.
David Wilt
The New Standard LLC
Message 2 of 12
(4,245 Views)
If you mean headless then no, just for raspberry pi or beaglebone.
But you can use arduino comunication to use a standalone VI executable.
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
Message 3 of 12
(4,228 Views)
hello,
what is arduino communication to use a standalone VI executable?
the standalone app I have build does not connect to arduino. when run via VI it works fine, it creates firmware and uploads to arduino. i think the standalone app does not connect,upload code to arduino. is this solvable?
Message 4 of 12
(4,178 Views)
It sounds like you are not talking about running headless so yes.
I don't think you need to upload the firmware everytime.  Please explain what you are doing in more detail.  Provide your VI or screenshots of your code for reference.
David Wilt
Message 5 of 12
(4,168 Views)
hi,
below is the block diagram of led blink program using linx for arduino.
When i run from the labview the program is working(led is blinking on arduino). But when i create standalone application it is not working.
Message 6 of 12
(4,165 Views)
When you say: ". But when i create standalone application it is not working"
you mean without usb connection to arduino?
if you mean that, in fact it will not work. This does not compile a code to arduino.
Sistema Fiep
CLAD, CLD
Message 7 of 12
(4,162 Views)
yes, i think when using VI from labview the code gets complied and uploaded to arduino. But when creating and using standalone app i think the code does not get uploaded.
So is there a way to get standalone app to work with arduino?
Message 8 of 12
(4,158 Views)
The code is not compiled and uploaded, you will always need a serial connection to communicate the arduino and PC. If you need a headless application, i sugest using raspberry pi.
There is a compiler, however i have not tested.
https://www.vipm.io/package/tsxperts_aledyne_lib_arduino_compiler_for_labview/#:~:text=The%20Arduino....
Sistema Fiep
CLAD, CLD
Message 9 of 12
(4,147 Views)
What do you mean by standalone app?
1.  Do you mean an exe running on a PC connected to an Arduino?  This is possible.
2.  Do you mean you expect the Arduino to do something based on the LabVIEW VI without be being connected to a PC running a LabVIEW application?  This is not possible.  This is referred to as headless, no PC is connected to the Arduino.
David Wilt
Message 10 of 12
(4,140 Views)
