Hobbyist Toolkit
LabView LINX - Connection to the target (raspberrypi) has been lost
I face the same issue with you, let me try to disable the 1-wire interface as your suggestion.
Yes, great! After disable the 1-wire interface, this issue is really resolved.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
Message 11 of 11
(944 Views)
