Hobbyist Toolkit
LabVIEW Community Edition 2025 + Raspberry PI 5
Hello everyone,
I'm trying to install LabVIEW RT on a Raspberry Pi 5 running the 32-bit Bookworm OS. The LINX.log file contains errors, as shown below:
Connecting to target...
Successfully connected to target.
Successfully connected. Gathering target info...
Target configuration updated.
OS Version: 12.12
CPU: Raspberry Pi 5 Model B Rev 1.1
Systemd Version:
Has Internet Access: True
Device Type: Raspberry Pi 2 B
OS Version: 12.12
Systemd Version:
blacklist spi-bcm2708is not present.dtparam=spi=on already exists.i2c-dev already exists.i2c-bcm2708 already exists.blacklist i2c-bcm2708is not present.dtparam=i2c1=on already exists.dtparam=i2c_arm=on already exists.
Adding MakerHub feed...
deb [trusted=yes] http://feeds.labviewmakerhub.com/debian/ binary/
Updating package index. This may take over 30 seconds depending on your internet speed...
Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:3 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
Ign:1 https://feeds.labviewmakerhub.com/debian binary/ InRelease
Ign:4 https://feeds.labviewmakerhub.com/debian binary/ Release
Err:5 https://feeds.labviewmakerhub.com/debian binary/ Packages
404 Not Found [IP: 2606:4700:3030::6815:4df2 443]
Err:6 https://feeds.labviewmakerhub.com/debian binary/ Translation-en
Err:7 https://feeds.labviewmakerhub.com/debian binary/ Translation-en_GB
Hit:5 https://feeds.labviewmakerhub.com/debian binary/ Packages
Ign:6 https://feeds.labviewmakerhub.com/debian binary/ Translation-en
Ign:7 https://feeds.labviewmakerhub.com/debian binary/ Translation-en_GB
Reading package lists...
Installing LabVIEW...
Building dependency tree...
Reading state information...
lvrt25-schroot is already the newest version (25.1.0-2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Rebooting Target...
Checking target status...
Installation completed successfully. Click Launch Example to get started.
Ignoring Error: 56 NI_Subprocess.lvlib:Raw Subprocess.lvclass:_Select.vi:4540001<APPEND>
<b>Complete call chain:</b>
NI_Subprocess.lvlib:Raw Subprocess.lvclass:Interact.vi:2440001
NI_Subprocess.lvlib:Buffered Subprocess.lvclass:Pump.vi:6140001
NI_SSH.lvlib:Try Execute SSH Command.vi
NI_SSH.lvlib:Execute SSH Command.vi
LMH-LINX.lvlib:SSH Execute Command.vi
LMH-LINX.lvlib:SSH Async Execute Command.vi
LMH-LINX.lvlib:Reboot Target.vi
LMH-LINX.lvlib:Target Configuration.vi
Warning: Permanently added '172.30.33.199' (ED25519) to the list of known hosts.
Rebooting.
Moreover, the detected device is listed as ‘Device Type: Raspberry Pi 2 B’, but it should be identified as a Raspberry Pi 5 instead.
Do you have any explanation?
shdkia
(1,146 Views)
The log does show a few errors, but it also looks like LabVIEW was successfully installed.  Can you connect to your RPi from the LV project and run a VI?
(1,126 Views)
I'm pretty sure he can:
https://forums.ni.com/t5/Hobbyist-Toolkit/PmodALS-doesn-t-work-on-the-SPI-bus-Raspberry-Pi-5/td-p/44...
Rolf Kalbermatter  My Blog
(1,114 Views)
Hello again,
Yes, you are right. There are a few errors, but I can run my program on the RPI 5 without any problems.
I think these errors are due to the fact that the current folder
https://feeds.labviewmakerhub.com/debian/binary/
doesn't include all the required files.
(1,110 Views)
I think some of the messages may be because the MakerHub feed entry is for a http request and the sever may now only support https requests.  The request is repeated by the PI OS as a https request and downloads the files ok.
(1,026 Views)
