Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
High-Speed Digitizers
Custom output trigget signal with USB-5132
I have a question regarding output trigger functionality with USB-5132. I found that it is possible to configure an output signal through PFI 1 channel for an external device once signal in CH 0 passes the threshold, and that the trigger signal can be Start Trigger or a few other options.
Is it possible to customize this output signal? For my application, I need a sound signal to be triggered from PFI 1 once an input in CH 0 passes the threshold, so sampling rate of ~44 kS/s and output length of at least a few seconds.
I am aware that oscilloscope device is not ideal for this in general, I am just wondering whether this is possible as in my university department, we already have the USB-5132. In case it is not possible, what devices you would recommend?
(2,331 Views)
Hi PaulinaS,
The PFI1 line on the USB-5132 is used for triggering or clocking configurations (or the use-case of probe compensation, which generates a defined 1kHz sine wave). Here's the system block diagram:
It sounds like you want to output an analog waveform based on a trigger, which won't be supported with the 5132. You'll want a USB-DAQ that's more general purpose which you can find here. You can filter the bus connector and analog output to fit your requirements and see the possible devices.
Cheers,
Nick
(2,289 Views)
