High-Speed Digitizers
NI USB 5133/ NiScope / Labview
Regards to everyone.
It would be very simple but i am stuck with the following problem.
I am new to labview. Please suggest me, how to do it.
I want to acquire multiple records of a single channel acquisition with NiScope and Lab-view.The card is USB 5133 High Speed Digitizer.
Trigger is external trigger (negative edge triggered pulses) at 100 ms duration to PFI1 pin.and I want to acquire and save multiple records : each record of 1500 samples, (at 30 MS/s and for 50 microseconds ) between triggers for complete 10 seconds.
I could able to do the acquisition part with the example available; " NiScope Ex Configured Acquisition.vi".
but i am not getting, how to save the records in a file which are being displayed on waveform graph.
if any loop , i need to add, please help me.
Thanks and Regards.
(3,903 Views)
Have you looked at the below example? Its show how to save waveform data to a file and load from a file. Its a simple one Hope this will help.
(2,874 Views)
