Hardware Developers Community - NI sbRIO & SOM
sbRIO-9651 SOM IO Interface and CLIP Generator.pptx
This presentation covers what a CLIP is, how to navigate through the sbRIO CLIP Generator, and how to import a socketed CLIP into your LabVIEW Project.
Tannerite
Message 1 of 20
(24,626 Views)
 Hi, Sir
This is Ian from NITW, I use sbRIO-9607, then I need 2 RS-232 port to use VISA, but when I finish the CLIP generator, I can't find the socket in my project, so I don't know how to Import the CLIP, (as the ppt's page 38).
What's wrong in my way? thanks.
Message 2 of 20
(21,138 Views)
If I understand you correctly, you cannot find the RMC Socket project item in your LabVIEW project. Is that correct? Can you attach a screenshot of your project? It should appear under your FPGA project item.
Message 3 of 20
(21,136 Views)
Add my Attach screenshot, thanks.
Message 4 of 20
(21,106 Views)
I can not choose the CLIP which I generated.
Message 5 of 20
(21,095 Views)
You've already added the digital RMC (9694) to your project, as shown below circled in red. If you remove that, you'll see the RMC socket appear.
Message 6 of 20
(21,067 Views)
Thanks, Deagle.
It's really help.
Message 7 of 20
(20,980 Views)
Hi tannerite,
I have a very related problem with this issue in my project, my hardware is NI sbRIO9607. I want to use the RS232 serial interface provided by Labview Clip Generator and I have also done all the necessary assignments written. But I could not find any way to access to the created port (serial nor parallel created by Clip Generator), with VISA or MAX. All DIO pins are working correctly without using in a Clip Generator serial port. However, only the ASRLx::INSTR ports could be accessed via MAX or VISA. According to the quote from your publication which I put to the beginning, I understand that ASRLx::INSTR ports are the corresponding Serial Ports. However there is no data communication sensed while I am testing the pins by this assignment (i.e. I considered Serial2 is ASRL2::INSTR , and all of the other ASRLx::INSTR ports are also tested whether one of them might be the Serial2 port or not). I put screenshots below.
How could I access this Clip Generator ports, could you please help me?
Thank you very much,
Best Regards,
Onur YILDIZ
RT VI CodeRT VI Code
Clip Generator ConfigurationClip Generator Configuration
Clip Generator SummaryClip Generator SummaryRMC Socket Properties ConfigurationRMC Socket Properties ConfigurationProject ExplorerProject ExplorerRT VI InterfaceRT VI InterfaceNI MAX InterfaceNI MAX Interface
Message 8 of 20
(19,973 Views)
Hi!
Could it be possible to use the additional serial (ASLR:2) while using the RMC card. In my case, I'm using RMC 9694 but whenever I add RMC card my "Socketed Clip" disappears. Can you please tell me the way out?
Message 9 of 20
(16,622 Views)
Hi!
I'm having the similar problem. Could it be possible to use the additional serial pin (ASLR:2) simultaneously with the RMC card. In my case, I'm using 9694 but whenever I add the RMC card my "Socketed Clip" removes from the project. Can you please tell me the way out to simultaneously used both of them.  My application requires two serial ports.
Message 10 of 20
(16,621 Views)
