G#
error
this class, i create property will occur error.
(11,540 Views)
labview2020 32bit
(11,539 Views)
R-click -> G# -> Create property?
Or drop a Property node in the block diagram?
I can't reproduce it, it seems to work in 2020 SP1.
What's the error you get?
Qestit Systems
Certified-LabVIEW-Developer
(11,502 Views)
Accepted by topic author yanzhanglin
I get an error too. Is this what you get?
The reason is that the attribute name "Lens Parameter" ends with a space, and LabVIEW returns error 7 when trying to save a copy of a file that ends with a space.
Certified LabVIEW Architect
(11,489 Views)
THANK YOU!
(11,476 Views)
