G#
Inheritance Error?
Hello everyone:
       When I create Queue_Support Class as farther,then I create UI_Class inherit from Queue_Support Class directly, UI_class works.but when I create Update Loop class,then I click change Inheritance,choose Queue_Support as Update Loop class'farther,Update Loop class doesn't works(create error).what's the matter?
       I am very sorry for that my english is very poor.
Message 1 of 12
(14,885 Views)
it seems that when change Inheritance,Kenerl.VI doesn't update correctly.
Message 2 of 12
(14,878 Views)
Accepted by yanzhanglin
Are you on LabVIEW 2020? I found a bug that happens when you change inheritance in LV2020. What happens is that all Call By Parent nodes gets replaced by the actual VI, which results in infinite recursion and out of memory error. This only occurs in LV2020.
Certified LabVIEW Architect
Message 3 of 12
(14,877 Views)
yes, I use labview2020
how can I deal with this problem,or When will it be fixed
Message 4 of 12
(14,874 Views)
it means that G# can't be used in lv2020?
Message 5 of 12
(14,859 Views)
No, it means that if you change inheritance in LV2020 using the built-in G#-function, you will need to manually replace all the instances of the changed class' kernel.vi in kernel.vi with the Call by Parent node. Just search for all instances of that VI in that VI and do a replace.
Message 6 of 12
(14,844 Views)
If the COVID19 didn't impact the release schedule, the 2020 SP1 release should be happening anytime soon. Given the severity of this bug, my gut feeling is that it will be fixed within this release.
Cheers
Andrea
Message 7 of 12
(14,836 Views)
Strange. I wonder what has changed in LV to cause this. We're Calling the standard LVOOP change inheritance i assume?
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 12
(14,833 Views)
It's not a LabVIEW bug. It's that Call Parent Method was renamed to Call Parent Class Method. This method is excluded from when replacing SubVIs when changing inheritance. So its an easy fix in G#. I have attached an update of the failing VI which shall be put in <LabVIEW 2020>\resource\Framework\Providers\AddQ\G#IDE\support\ScriptingLib.
I just updated to LV2020 f1, but since that did not help with this issue I opened up the G# code and it was pretty simple to find.
To anyone else who wants to contribute, the code is at https://github.com/weaddquality/gsharp
Perhaps there are other places in the G# code which relies on the name of a VI which had its name change with the introduction of interfaces in LabVIEW?
Message 9 of 12
(14,748 Views)
Does G# update in VIPM?
Message 10 of 12
(14,745 Views)
