G#
what's the differences between G# and Actor Frameworks?
which one is better?
(6,958 Views)
Better? That question makes no sense. They are different Tools that solves different problems.
G# is a tool that allows you to have reference based classes in LV.
AF is a design system that sends data/commands through queues.
They can be combined if you like. 🙂
So, what are you trying to build and which problem are you trying to solve?
Qestit Systems
Certified-LabVIEW-Developer
(6,925 Views)
How to create G# class in AF??
(6,901 Views)
G# classes cannot be created in AF. Create G# classes with G#. What Yamaeda means is that both frameworks can be used in the same project.
Certified LabVIEW Architect
(6,875 Views)
Thols is right (as usual) 🙂
To expand on it; i haven't tried, but i assume you can use G# classes as parameters or consumers in an AF-system. I don't know when this would be a good idea, but it'd basically be like sending a DVR to some data as part of a message.
Qestit Systems
(6,871 Views)
Let me add that before launching the root actor you have to start the external create process (call G#Object_StartExternalCreateProcess.vi) lest your G# class might disappear when the actor that created them stops executing.
(6,868 Views)
