G Web Development Software
Hyperlink leaflet
I was experimenting with the following example: https://rajsite.github.io/webvi-experiments/Leaflet/ and I am attempting to make the popup text a hyperlink. I have tried modifying the function in JavaScript but without success. I am unsure if it is possible to pass a hyperlink as a string using JSLI. Here is the modification I made to the original function:
const createMarker = function (configJSON) {
const config = JSON.parse(configJSON);
const options = {};
if (config.iconUrl !== '') {
options.icon = L.icon({
iconUrl: config.iconUrl,
iconAnchor: L.point(config.iconAnchor.x, config.iconAnchor.y),
popupAnchor: L.point(config.popupAnchor.x, config.popupAnchor.y)
const marker = L.marker([config.coordinate.latitude, config.coordinate.longitude], options);
if (config.popupText !== '') {
// marker.bindPopup(config.popupText);
const hyperlink = `<a href="https://www.example.com" target="_blank">${config.popupText}</a>`;
marker.bindPopup(hyperlink);
return marker;
However, it did not work. I considered an alternative where I would retrieve the coordinates from the panel where the popup text appears and make the hyperlink show up, but I also could not find a way to make this work.
Thank you in advance for your assistance.
(2,787 Views)
Accepted by topic author Labmecepel
Using the Maps for WebVI example you can include links in the popup text like follows:
And they will be rendered in the popup:
Milan
(2,770 Views)
I appreciate it once again.
(2,739 Views)
