Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
05-30-2022 02:35 AM
hi, guys
I build a web application from WebVI examples by G Web dev-soft, and then copy the entire web application to the server directory. But it doesn't work properly.
I saw it:
Solved! Go to Solution.
05-31-2022 03:50 AM
Did you enable the wasm MIME type support?
"... You may need to configure a 3rd party server to support the application/wasm MIME type for files with the .wasm file extension .."
05-31-2022 04:50 AM
Yes. Anything else?
05-31-2022 04:51 AM
Yes. Anything else?
06-01-2022 02:28 AM
By the way, the same web application running on the virtual host is correct.
06-01-2022 02:46 AM
Correct explanation:
Please refer to the OS/Network admin as this issue is likely a DNS issue where the client PC is unable to reach the master using the IP/hostname value seen in error.
A possible solution is to edit the hosts file and add an entry for the IP and hostname value. Please refer to OS/Network admin for more information.
Thanks.
