G Web Development Software
Deploy to third-party server
hi, guys
I build a web application from WebVI examples by G Web dev-soft, and then copy the entire web application to the server directory. But it doesn't work properly.
I saw it:
Unable to load resource file
Verify all WebVI files are available and served using an HTTP server or use a browser that can load files directly from the file system. See Hosting a Web Application on a Server for more information.
Anyone have any ideas?
wuxw
(2,388 Views)
Did you enable the wasm MIME type support?
"... You may need to configure a 3rd party server to support the application/wasm MIME type for files with the .wasm file extension .."
(2,358 Views)
Yes. Anything else?
(2,349 Views)
Yes. Anything else?
(2,349 Views)
By the way, the same web application running on the virtual host is correct.
(2,323 Views)
Accepted by wuxw
Correct explanation:
Please refer to the OS/Network admin as this issue is likely a DNS issue where the client PC is unable to reach the master using the IP/hostname value seen in error.
A possible solution is to edit the hosts file and add an entry for the IP and hostname value. Please refer to OS/Network admin for more information.
Thanks.
(2,316 Views)
