10-18-2011 10:15 AM
i am looking for a manual for the FP-1100 fieldpoint DeviceNet network module.
any help would be greatly appreciated!
Solved! Go to Solution.
10-19-2011 04:30 PM
Hello reichenbach,
This is Andrew Brown, an Applications Engineer from National Instruments. After researching the module you have described (FP-1100 network module), I have been unable to find either documentation or any references this module. The main pages I checked are the directory of National Instruments manuals and the main National Instruments website.
Do you currently have access to this FieldPoint module? If so, can you please double check the model name?
Andrew Brown
10-19-2011 04:41 PM
here is a photo of it: http://www.artisan-scientific.com/itemimages/NI_FP_1100_View1.jpg
upon further review, the processor board is labeled as such:
National Instruments FP-110X Processor Board ASSY185075A-01
there is not a part number or serial number on the outside of the unit.
Do I have a demo or prototype unit?
10-20-2011 05:30 PM
Hello reichenbach,
Thank you for the photo and additional info. I don't believe you have a demo or prototype, but I will need to investigate in order to determine if / where a manual might be. I will keep you posted of my results.
Andrew Brown
10-21-2011 09:35 AM
Thanks Andrew!
10-21-2011 01:54 PM
Hello reichenbach,
Attached to this post is the user manual for the FP-1100 DeviceNet network FieldPoint module. This module is no longer supported by National Instruments, but the manual should be a very helpful resource.
Andrew Brown
10-25-2011 10:19 AM
Andrew,
Thanks for the manual! This is exactly what I was looking for!
